Error e0046: "Processing failed. Cannot convert the GCPs coordinate system to the output coordinate system."
Error
Description
When processing step 1. Initial Processing, the processing stops and shows the message: e0046: "Processing failed. Cannot convert the GCPs coordinate system to the output coordinate system."
Cause
The transformation between the GCP coordinate system and the output coordinate system does not exist or the coordinates are not correct.
Solution
  • Verify that the GCP coordinate system can be transformed to the output coordinate system. For more information: 203032269.
  • Verify that the GCP geolocation is correct. For more information: 203032289.
0 out of 0 found this helpful
