To get the outputs of a project that is already processed using Pix4Dmapper Discovery:
Outputs of step 1. Initial Processing
None of the outputs require to process step 1 again in order to be generated / exported.
- Camera Internals and Externals, AAT, BBA
1. On the Menu bar, click Process > Options...
2. Select the processing step 1. Initial Processing.
3. Select Advanced (at the bottom left corner).
4. Select the tab Calibration.
5. In the Output section, select Camera Internals and Externals, AAT, BBA: Menu Process > Processing Options... > 1. Initial Processing > Calibration.
6. On the Menu bar, click Process > Generate Quality Report: Menu Process > Generate Quality Report.
- Undistorted Images
On the Menu bar, click Process > Save undistorted images: Menu Process > Save Undistorted Images.
Outputs of step 2. Point Cloud and Mesh
None of the outputs require to process step 2 again in order to be generated / exported.
- Densified Point Cloud
It is generated during step 2. Point Cloud and Mesh, but cannot be exported using the Discovery version.
To export the point cloud from the rayCloud with the Pro version: How to export the Point Cloud.
- 3D Textured Mesh
To generate the 3D Textured Mesh: Menu Process > Generate 3D Textured Mesh.
Outputs of step 3. DSM, Orthomosaic and Index
None of the outputs can be generated using Pix4Dmapper Discovery. Run step 3 to generate the outputs of step 3. DSM, Orthomosaic and Index.
Check the processing options before running step 3. For more information: Menu Process > Processing Options... > 3. DSM, Orthomosaic and Index > DSM and Orthomosaic.
