Error: The cabinet file disk1.cab required for this installation is corrupt and can not be used
Error
"The cabinet file disk1.cab required for this installation is corrupt and can not be used."
Description
This error appears when installing the software.
Cause
The cause might be:
  • Installing the software on Windows XP.
  • Corrupted file system.
  • Corrupted hard drive.
Solution
1. Verify that the computer complies with the minimum system requirements: System requirements: Minimum and recommended computer specifications.
2. Verify that the file system is not corrupted.
3. Verify that the hard drive is not corrupted.
4. Try to install the software on another computer.
For more information about the problem and its causes/solutions: http://winwiki.org.
Disclaimer: Pix4D publishes this information as a courtesy to its customers. Because this information may not be accurate, Pix4D makes no warranty of any kind, expressed or implied, with respect to its validity.
0 out of 4 found this helpful
