Pix4Dmapper leverages the power of Nvidia GPUs for faster processing.
The speed increase depends highly on the project, the number of images, the image size, and the image content. For example, with a GTX 970 a speedup between 10% and 75% on step 1. Initial Processing, and around 10% in step 2. Point Cloud and Mesh was observed. As a rule of thumb, projects with high overlap, high image content and thus with a high number of keypoints benefit more from the speedup.
Minimum requirements for CUDA speedup
Nvidia GPU (GTX, Mobile, Tesla, Titan, Quadro) with at least 2GB RAM, supporting CUDA 9.1 with the latest driver installed (starting at least from 343).
Recommended GPU
GTX 750, GTX 970 (around 200-400$), GTX 1060, 1070, 1080 with latest driver installed.
How to enable GPU processing
If a GPU with CUDA support is automatically detected, it will be automatically used for processing.
The use of the GPU can be enabled or disabled in the Processing Options:
1. In the Menu Bar, click Process > Processing Options...
2. Select Resources and Notifications.
3. In the Maximum Resources Available for Processing section, select or unselect the GPU device.
Olá a todos!
Tentei instalar o Pix4D em 3 novos computadores com GPU AMD RADEON, mas nenhum desses computadores Pix4Dmapper reconheceu a GPU. Estou enviando a impressão de um desses cartões.
Pix4Dmapper não suporta este tipo de GPU?
Olá Paulo!
Infelizmente, Pix4Dmapper não suporte OpenCL. É por isso, você não poderá usar a placa AMD para computação.
No entanto, Pix4Dmapper trabalha com NVIDIA CUDA.
Leia mais sobre este tópico aqui.
Saudações
Buenas tardes desde Bolivia, comprare un ordenador, cual de las siguientes son compatibles para el uso de PIX4D SCAN / INSPECTION.
Les quedo agradecido por su ayuda
1.
ASUS
PROCESADOR: I5 10300H (10MA GENERACION)
VELOCIDAD: 2.50 GHZ
VIDEO: GTX 1650 TI/ 6 GB
RAM: 16 GB DDR4
DISCO DURO: 256 GB SSD
VIDEO: DEDICADO 6GB NVIDIA GTX 1650 TI
________________________________________________
2.
MSI GF-65
PROCESADOR: I7 9750 H
RAM: 16 GB DDR4
VIDEO: RTX 2060 / 6 GB
DICO SOLIDO: 512 GB
3.
HP X360
RAM: 16 GB DDR4
VIDEO: GTX 1650 / 4 GB
4.
ASUS ZEPHYRUS
PROCESADOR: I7 10750 H
RAM: 16 GB DDR4
VIDEO: GTX 1660 TI / 6 GB
