How to process images with big color variance
Images that have big color variance could cause issues in processing, as it is difficult to match the extracted keypoints in different images.
Images with color variance
In such cases, it is recommended to process without modifying or pre processing the images.
If the reconstruction is not satisfactory you can try to:
  1. Add Manual Tie Points. For step by step instructions: 202560349.
  2. If the results are still not satisfactory, as a last resort the images could be modified using an image editing software, like Photoshop, in order to balance the color between the images.
1 out of 3 found this helpful
Article feedback
