English
How many Points are generated during step 2. Point Cloud and Mesh? - PIX4Dmapper
This article displayed the average number of points that may be generated during step 2. Point Cloud and Mesh in PIX4Dmapper.
The number of points that are generated during step 2. Point Cloud and Mesh depend on several factors such as the image size, image content, image overlap, and processing options. Therefore, it is not possible to precisely estimate the number of points generated during step 2. However, some statistics about the number of points of the point cloud could be made and are shown below.
Estimated number of points observed in projects with 14 MP images
The used options for step 2. Point Cloud and Mesh:
  • Image Scale is 1/2 (Half image size).
  • Point Density is Optimal.
  • Minimum number of Matches: 3
Number of images
Number of points
LAS file size
250
20 - 50 million
0.3 - 1.0 GB
500
40 - 60 million
1.2 - 1.9 GB
1000
80 - 120 million
2.5 - 3.8 GB
Note:
  • The size of the LAS file depends on the number of points. One point will take 34 bytes disk space.
  • The above-mentioned numbers are only estimates and depend on the image size and content. For example, urban areas projects will have more points than desert or snow area projects.
Estimated impact of processing options on the number of points generated
There are 2 processing options for step 2. Point Cloud and Mesh that have an impact on the number of points generated:
  • Image Scale
  • Point Density
For more information about the processing options: Menu Process > Processing Options... > 2. Point Cloud and Mesh > Point Cloud.
The following table summarizes by which factor the number of points obtained with the default options changes when changing the Image Scale and Point Density.
Image Scale \ Point Density
1 (Original image
size, Slow)
1/2 (Half image
size, Default)
1/4 (Quarter image
size, Fast)
1/8 (Eighth image
size, Tolerant)
High (Slow)
x16
x4
Same as default
÷4
Optimal
x4
DEFAULT
÷4
÷16
Low (Fast)
Same as default
÷4
÷16
÷64
Example: A project of 500 images of 14 MP generates a point cloud of 40 million points using the default options. The following table displays how many points are generated depending on the selected processing options.
1 (Original image
size, Slow)
1/2 (Half image
size, Default)
1/4 (Quarter image
size, Fast)
1/8 (Eighth image
size, Tolerant)
High (Slow)
640 million
160 million
40 million
10 million
Optimal
160 million
40 million
10 million
2.5 million
Low (Fast)
40 million
10 million
2.5 million
0.625 million
Note: The default processing parameters give already a high quality point cloud. Increasing the number of points generated by the default parameters does not necessarily increase the quality of the point cloud.
