Example datasets available for download: Quarry
Quarry
The goal of this project is to generate a DSM and an Orthomosaic of a quarry using a Canon IXUS 220HS.
Densified Point Cloud 3D Textured Mesh Point Cloud - Objects Point Cloud - Terrain DTM Raster DSM Orthomosaic Grid DSM
Google Maps Tiles KML Pix4D Cloud Contour Lines 3D PDF
General project information
Project
Location Switzerland
Average Ground Sampling Distance (GSD) 8.78 cm / 3.46 in
Area covered 0.5776 km2 / 57.7565 ha / 0.223 sq. mi. / 142.79 acres
Output coordinate system WGS84 / UTM zone 32N
Vertical Coordinate System: Geoid Height Above WGS 84 Ellipsoid = 0 meters
Image acquisition
UAV swinglet CAM (senseFly)
Image acquisition plan 1 flight, grid flight plan
Camera Canon IXUS 220HS (RGB)
Images
Number of images 127
Image size 4000x3000
Image geolocation coordinate system WGS84
GCPs
Number of GCPs 7 3D GCPs
GCPs coordinate system WGS84
Download* and project files
The dataset can be downloaded here.
The dataset can be found processed on Pix4D Cloud here
  • imagesRGB images in JPG format
  • inputs/gcp_overview: images that help to identify each GCPs
  • inputs/gcpPositionsLatLongAlt.csv: GCP input geolocation file.
  • example_quarry.p4dproject file that can be opened in Pix4Dmapper.
*The usage of this dataset is meant to be for personal and professional training. If you would like to use it for commercial or promotional objectives, please be sure to mention "Courtesy of Pix4D / pix4d.com" linking all this text to pix4d.com.
Instructions
Follow the instructions to:
Process the dataset using the included .p4d project file
This section describes how to process the dataset in order to generate the DSM and the Orthomosaic of a quarry.
1. Open the project example_quarry.p4d
2. On the menu bar, click View > Processing. The Processing bar opens at the bottom of the main window.
Note: As the goal of this project is to generate the DSM and the Orthomosaic, and as it has been taken using aerial nadir images, the template used for the Processing has been set to 3D Maps. This can be seen in Process > Processing Options....
 3. On the Processing bar, click Start to start the processing.
Process the dataset creating a new project
This section describes how to create and process a project in order to generate the DSM and the Orthomosaic of a quarry.
A) Create a new project:
1. Start Pix4Dmapper.
2. On the Menu bar, click Project > New Project....
3. The New Project wizard opens.
4. In Name: Type a name for the project. In this example type example_quarry.
5. (optional) In Create In: click Browse..., and in the Select Project Location pop-up, navigate to select the folder where the project and results will be stored and click Select Folder
Note: When the project is created, a folder named after the project name typed in the Name field will be created in the selected folder and will store all the results. The .p4d project file will also be stored in this folder.
6. (optional) Select the check box Use As Default Project Location to save all new projects in the selected folder.
7. In the section Project Type, keep selected the default option New Project.
8. Click Next.
The New Project wizard displays the Select Images window.
9. Click Add Directories... and select the images folder to add the images to the project.
10. Click Next.
The New Project wizard displays the Image Properties window. The image geolocation is automatically loaded from the image EXIF data and is given in WGS84 (latitude, longitude, altitude) coordinates with vertical coordinate system given by a Geoid Height Above WGS 84 Ellipsoid of 0 meters. The camera model is loaded from the camera model database (CanonIXUS220HS_4.3_4000x3000 (RGB)).
11. Click Next.
The New Project wizard displays the Select Output Coordinate System window. By default the last output coordinate system selected in the software is selected.
12. Select Auto Detected.
13. Select Advanced Coordinate Options and under Vertical Coordinate System select Geoid Height Above WGS 84 Ellipsoid. Set the value to 0.
14. Click Next.
The New Project wizard displays the Processing Options Template window.
15. Click 3D Maps to select the template.
Note: As the goal of this project is to generate the DSM and the Orthomosaic, and as it has been taken using aerial nadir images, the template to be selected is the 3D Maps.
16. Click Finish to finish the wizard and create the project. The Processing bar opens at the bottom of the main window.
B) Introduce and mark the GCPs:
1. On the Menu bar, click Project > GCP/MTP Manager....
The GCP/MTP Manager window opens. Change the GCP Coordinate System to WGS 84 with a vertical coordinate system given by a Geoid Height Above WGS 84 Ellipsoid of 0 meters.
2. On the GCP Coordinate System section, click Edit....
3. On the Select GCP Coordinate System window, set the Unit to m.
4. On the Select GCP Coordinate System window, select Known Coordinate System [m], type WGS 84 and select it in the drop-down list.
5. On the Select GCP Coordinate System window, select Advanced Coordinate Options and under Vertical Coordinate System select MSL egm96.
6. On the Select GCP Coordinate System window, click OK.
7. On the GCP/MTP Manager window, on the GCP/MTP Table, click Import GCPs....
8. On the Import Ground Control Points window, under Coordinates Order, select Latitude, Longitude, Altitude option.
9. On the Import Ground Control Points windows, click Browse, select the GCP file gcpPositionsLatLongAlt.csv from the inputs folder and click OK.
10. On the Import Ground Control Points windows, click OK.
The GCPs and their coordinates are imported and can be visualized in the GCP/MTP Manager window.
11. On the GCP/MTP Manager window click OK.
12. On the Processing bar select 1. Initial Processing, deselect 2. Point Cloud and Mesh and 3. DSM, Orthomosaic and Index.
13. On the Processing bar, click Start to start the processing.
When step 1. Initial Processing is finished the rayCloud opens.
14. Mark the GCPs using the rayCloud following instructions 2. to 11. as described here 202560769. The images in the folder inputs/gcp_overview help to identify the GCPs should be marked.
C) Generate the DSM and Orthomosaic
When the GCPs are marked and the project is re-optimized.
1. On the Processing bar, deactivate 1. Initial Processing and activate 2. Point Cloud and Mesh and 3. DSM, Orthomosaic and Index.
2. On the Processing bar, click Start to start the processing.
2 out of 4 found this helpful
