Error
Merged projects create more than one block and / or they do not adjust. The different blocks are displayed with different colors in the Quality Report: Quality Report Help.
Description
Cause
This issue may appears if each subproject creates one block and they are not merged properly since there is not enough union points between them due to low overlap between projects.
Solution
- Create Manual Tie Points in the intersection area between projects and Reoptimize following (step 18 and onward): Merging projects.
- Use the Rematch option in order to generate more matches: Menu Process > Processing Options... > 1. Initial Processing > Calibration
it is very difficult to recognize (from Quality Report) different blocks in order to connect via MTP
Hi,
Thank you for your feedback. I understood from my colleague Rhea that your request was already reported.
Cheers,
Ina
Similar to the first comment, I'm finding it difficult to identify from the Quality Report or ray cloud exactly which portions are different blocks. This makes it difficult to determine where I should place my MTP. Is there a way to highlight the different blocks in the ray cloud?
Hello Larry,
Could you upload your Quality Report to our OneDrive so we could provide you with better assistance?
Thank you in advance!
