Error: merged projects create more than one block and / or they do not adjust
Error
Merged projects create more than one block and / or they do not adjust. The different blocks are displayed with different colors in the Quality Report: Quality Report Help.
Description
Cause
This issue may appears if each subproject creates one block and they are not merged properly since there is not enough union points between them due to low overlap between projects.
Solution
2 out of 4 found this helpful
6 comments
  • nucleo sapr
    it is very difficult to recognize (from Quality Report) different blocks in order to connect via MTP
  • Ina (Pix4D)
    Hi,
    Thank you for your feedback. I understood from my colleague Rhea that your request was already reported.
    Cheers,
    Ina
  • Larry Laxdal
    Similar to the first comment, I'm finding it difficult to identify from the Quality Report or ray cloud exactly which portions are different blocks. This makes it difficult to determine where I should place my MTP. Is there a way to highlight the different blocks in the ray cloud?
  • Avatar
    Beata (Pix4D)
    Hello Larry,
    Could you upload your Quality Report to our OneDrive so we could provide you with better assistance?
    Thank you in advance!
  • Karen Castañeda
    Hi
    When I merged the projects, the results are in different high. What can I do?
    Thanks
  • Kapil (Pix4D)
    Solution
