Cause
The orthomosaic is generated based on the DSM that is created from the Densified Point Cloud. Thereby, errors and noise present in the Densified Point Cloud will be reflected in the orthomosaic. These distortions occur because Orthorectification is used instead of Photo Stitching, for more information: Photo stitching vs orthomosaic generation.
When computing the Densified Point Cloud, the altitude of the points will not be perfectly estimated. There are always some errors and noise that are minimized for good datasets (high overlap, good visual content of the images, use of GCPs, etc.).
These errors and noise result in altitude differences for points that are supposed to be at the same altitude, such as points that belong to the same roof edge of a building or the same edge of a bridge. This altitude difference explains the distortions that appear in the orthomosaic on building edges, bridges, etc.
Solutions
- Improving building artifacts: How to correct Building Artifacts in the DSM and Orthomosaic.
Orthomosaic before editing | Orthomosaic after editing using the Mosaic Editor |
Figure 1. |
- Improving the aspect of bridges: How to improve the Visual Aspect of Bridges in the Orthomosaic with the Mosaic Editor.
Figure 2. |
pix4d is famous in the world ,should be begineer user easy to operation,but,i am a user,any setup correct or wrong ,i dont know how,HELP funtion too weak,when i finishing project, i found progress not complete ,why,i rent your monthly for year,so expensive,
your toturial teching video,only english,i am chinese who know english ,when setup project you must let user result .but your HELP like damage machine ,.
i very angry ,pix4d diffcult to use,i sugesting your company ,user always stupied ,anyway easy use,chip rental ,my problem also is all user problem.
i am a programer ,pix4d,not good software.i belive.in future you may loss your customer soon, .
bestregards afa8168@gmail.com by hung fu yuan TAIWAN
Hi Hung. Thanks for reaching out. If you are having issues with a project I would suggest opening a support request at support.pix4d.com. If you choose to open a support request please include a log file, quality report, and a description of the problem.
We are working to expand our supported languages so your feedback is helpful. Thank you.
这位湾湾的兄弟,好巧哦。看见你的此番表述或者也可以称之为是抱怨牢骚之后真是让人忍俊不禁,憋出内伤。
本人就职于祖国内地的一家甲级测绘单位,你要知到pix在内地的测绘领域简直是最低最低的入门级别软件,是所有想要和正在从事地信领域的人的最早上手的一款处理软件。它的简单易用性早在2014年至今都是人们所认可的,它优异的工具属性可以为其他更为高级复杂的处理软件例如CC、inpho、photomash等输出优秀的辅助数据,就像一位厨师手中最简单也最有效的一把刀具。
pix4d引以为傲的就是详细的在线帮助文档,是我所接触的众多软件中最为人性化和实用化,它不像其他软件的帮助文档冗长繁杂。pix用一步步详细步骤为客户解释所有选项,和选项改变的前因后果,真是让人由衷的感动。
我并不认为你已经翻遍了pix网站的所有帮助说明,如果可以,沉下心来,好好的去研读和练习。一味的抱怨只会让人怀疑你的能力,何况还是如此简单的一款入门软件。
不知道你有没有看过周星驰先生的《功夫》影片,里面有这么一句话:你想学啊?我教你啊。
