Error: Pix4D Desktop stopped working: "Fault Module Name: MSVCR90.dll"
Error
Pix4Dmapper stopped working: Fault Module Name: MSVCR90.dll
Description
Before the initial processing is completed the software shuts down, displaying the message:
error code: Problem signature
Problem Event Name: BEX64
Application Name: pix4dmapper.exe
Application Version: 0.0.0.0
Application Timestamp: 52d4162c
Fault Module Version: 9.0.30729.6161
Fault Module Timestamp: 4dace4e7
Exception Offset: 00000000000552d4
Exception Code: c0000417
Exception Data: 0000000000000000
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: 2ee0
Additional Information 2: 2ee06f7eccd09afbeffef96193350cec
Additional Information 3: 1a29
Additional Information 4: 1a2938912226de2f0c15bd494922089b
Causes
In some cases, msvcr90.dll errors could indicate a registry problem, a virus or malware issue or even a hardware failure.
Msvcr90.dll errors may lead to the removal or corruption of the msvcr90.dll file.
Solution
Check the different solutions provided in the following link: http://pcsupport.about.com/od/findbyerrormessage/a/msvcr90-dll.
Disclaimer: Pix4D publishes this information as a courtesy to its customers. Because this information may not be accurate, Pix4D makes no warranty of any kind, expressed or implied, with respect to its validity.
0 out of 1 found this helpful
