Error: Duplicates Images when Merging Projects
Error
When merging two projects, using a set of the same images in both projects, these images are duplicated instead of being treated as the same image.
Cause
When the same image is used in at least 2 of the sub projects being used in the merging and, instead of using the same image for the sub projects, the image has been duplicated/copied and each sub project points to a different file.
Solution
Do not copy and duplicate the same image into another directory. Keep one copy of the image and point to it in all the sub projects that share the image and will be merged.
1 out of 1 found this helpful
Powered by Zendesk
