Pix4Dmapper freezes after Initial Processing is done when opening the rayCloud.
Error
Description
The Initial Processing is successfully completed. While the rayCloud is opening, Pix4Dmapper freezes.
Cause
The rayCloud opens automatically after Initial Processing. The rayCloud consumes a lot of RAM just for visualizing the results.
Workaround
1. As a first workaround:
1. Close the project
2. Open it again.
3. Run the 2nd and 3rd step (Point Cloud Densification and DSM and Orthomosaic Generation) without opening the rayCloud.
2. If the above mentioned solution does not solve the problem:
1. Change the Point Cloud Densification options, so that less points are generated. For more information: 202557799. (see Point density).
0 out of 3 found this helpful
