The Model appears upside down / rotated at the Outputs
Error
The area of your project appears upside down / rotated at the Pix4Dmapper outputs (orthomosaic, kml file, DSM).
There is also big difference between the initial focal length and the optimized one as it is calculated by Pix4Dmapper calibration.
Description
The area of the project appears significantly rotated or turned at the results. On the Quality Report on Optimized camera position section, there is a big rotation of the input camera position and the optimized one.
Figure 1. From Quality Report: Offset between image geotags (small red crosses) and optimized positions (small blue dots).
Cause and Solution
For information about the cause and instructions to solve the issue: 202560899.
0 out of 0 found this helpful
Powered by Zendesk
