Error
Images and/or GCPs do not lay at the correct position on the 2D Map.
Description
When importing in a project:
- Images with geolocation (known coordinates).
- GCPs (points with known coordinates).
They should be displayed more or less in the right position on the 2D Map, but they do not.
For more information about the 2D Map: Menu View > Map View > 2D View.
Cause
The possible causes are:
- The image and/or GCP input coordinates are not correct.
- The image and/or GCP selected coordinate system are not correct.
Solution
Depending on the cause of the problem, the solutions are:
- The image and/or GCP input coordinates are not correct:
1. Check that the coordinates are correct.
2. Check that the image geolocation file and/or the GCP georeference file has been correctly imported. For more information about the:
- Image geolocation file: Input files.
- GCP georeference file: Input files.
- The selected image and/or GCP coordinate system are not correct:
1. Check that the correct coordinate system has been selected. For more information about the:
- Images coordinate system: How to select / change the Image / GCP / Output Coordinate System.
- GCPs coordinate system: How to select / change the Image / GCP / Output Coordinate System.
I am in Australia and when i manually enter the known 3D GPS coordinates into "GCP/MTP Manager", Pix4D Mapper locates the GCP markers in Antarctica. This happens both when I try to do this before initial processing or via the "ray cloud" after processing. Even though the map after initial processing is almost exactly in the correct location.
Any ideas to help me locate the GCP markers where they are supposed to be and not at the South Pole?
Hi Glenn, in most cases this happens when either the wrong coordinate system is selected or when the order of coordinates is not correct.
Could you share the name of the coordinate system that you use (e.g. WGS 84) and one of the GCPs coordinates (e.g. GCP0,46.23456,6.56114,299.931)?
Best,
Yes, we are using WGS84. Imagery taken with Phantom4 V2.
I was entering the coordinates manually via "ray cloud". Example of coordinates;
-33.6862021,117.0325893,262.398
(lat,long,alt)
I think the problem is that a projected coordinate system (UTM zone) was selected while the coordinates are in a geographic coordinate system (latitude, long).
Changing the coordinate system to WGS 84 (geographic) should solve the issue:
This seems to have worked to bring things back to same location. Thanks
