Error e0010: "Could not import selected coordinate system from .prj."
Error
Error importing .prj file with the coordinate system.
Description
It might appear when importing the coordinate system definition from a .prj file in Image Properties or GCP Editor or Output Coordinate System window.
Cause
The format of the .prj file might not be correct.
Solution
Check the format of the .prj file or create a new .prj coordinate system syntax file: 202559979.
0 out of 0 found this helpful
