How to generate the Contour Lines
Video: Watch the instructional video related to Contour Lines and DTMhere.
Important: The contour lines are computed using the:
During processing step 3. DSM, Orthomosaic and Index
The contour lines are not selected in the processing options in the default, predefined Processing Templates. Modify the options following:
2. Select the processing step 3. DSM, Orthomosaic and Index.
3. Select the tab DSM and Orthomosaic.
4. In the section Raster DSM, make sure that GeoTIFF and Merge Tiles are selected.
5. Select the tab Additional Outputs
6. In the section Contour Lines, select the desired output formats (SHP, PDF, DXF).
7. (optional) Change the Contour Base [unit]Elevation Interval [unit], Resolution [cm] and Minimum Line Size [vertices] values. For more information about the contour line options: Menu Process > Processing Options... > 3. DSM, Orthomosaic and Index > Additional Outputs.
8. Click OK.
9. Select step 3. DSM, Orthomosaic and Index and click Start.
After processing step 3. DSM, Orthomosaic and Index
If step 3. DSM, Orthomosaic and Index has already been processed, it is possible to generate the contour lines without processing step 3 again:
3. Select the tab Additional Outputs.
4. On the section Contour Lines, select the desired output formats.
5. (optional) Change the Contour Base [unit]Elevation Interval [unit], Resolution [cm] and Minimum Line Size [vertices] values. For more information about the contour lines options: Menu Process > Processing Options... > 3. DSM, Orthomosaic and Index > Additional Outputs.
6. Click OK.
7. On the Menu bar, click Process > Generate Contour Lines (DSM) or Process > Generate Contour Lines (DTM).
Important: If raster DSM is not exported or the tiles of the raster DSM are not merged, the option is grayed out. In this case, generate the contour lines while processing step 3. DSM, Orthomosaic and Index as described above.
Note: The contour lines files are stored in:
...\project_name\3_dsm_ortho\extras\contours\project_name_interval_resolution_minimum_line_size_DSM.* or
...\project_name\3_dsm_ortho\extras\contours\project_name_interval_resolution_minimum_line_size_DTM.* depending on if it was generated using the DSM or the DTM.
14 out of 14 found this helpful
