Important: Available once step 1. Initial Processing is done and both the Reflectance Map and the Index Map have been generated.
Note: The Colored Index Maps are obtained by applying defined coloring rules to the Index Maps.
Warning: If a Colored Index Map already exists for the selected Index, generating the new Colored Index Map will overwrite the existing one.
In order to generate a Colored Index Map:
1. On the Menu bar, click View > Index Calculator.
2. (Optional) Change the number of Classes or how the Classes are defined. For more information: How to edit the Color Mapping in the Index Calculator.
3. In section 5. Export, click Export for exporting the Colored Index Map to the result folder.
