How to edit the point cloud in the rayCloud
Editing the point cloud allows to clean the 3D model by reducing noise and improving the precision as well as the visual rendering. This impacts the outputs of step 3 like the DSM and orthomosaic.
Access: Available once step 2. Point Cloud and Mesh has been completed.
In order to edit the point cloud points in the rayCloud:
1. On menu bar, click View > rayCloud.
2. If the densified point cloud is not loaded or displayed in the 3D view: In the section Layers on the left sidebar, select Point Clouds.
3. (optional) Visualize / hide the groups of the points to be edited: In the section Layers of the left sidebar, select / unselect the desired Point Groups.
Note: By default, all the points are Unclassified. When the point cloud classification has been performed, all the points are assigned in one of the predefined point groups. For more information: How to generate the point cloud classification.
4. In the toolbar, click Edit Densified Point Cloud in order to activate the editing mode.
5. The following pop-up message appears. Read it and click OK.
6.  By default  Add Points to Selection is selected. To select points, draw a polygon in the 3D View by using left mouse clicks. End the selection with a right-click. A red polygon highlighting the selected points is visible in the 3D View.
Drawing the rectangle Red rectangle marking the selecting points
7. (optional) To remove points from the selection: In the toolbar, click the arrow beside Add points to selection  and select  Remove Points from Selection. In the 3D View, on an area highlighted in red, left-click to draw a polygon around the points that have to be removed from the selection. End the polygon with a right-click. The selected area is not highlighted in red color.
8. (optional) To clear the current selection: In the toolbar, click the arrow beside Select All  and select  Clear Selection.
9. (optional) To invert the selection (i.e to convert all the non-selected areas to selected areas and vice versa): In the toolbar, click the arrow beside Select All  and click Invert Selection.
10. Once the points are selected: In the toolbar, click the arrow beside Unclassified and select the group to which the selected points will be assigned. In order to assign the points to a new group, click New Point Group. A pop-up appears, type the new point group name and click OK. The new group created is selected.
11. Click Assign.
Warning:
  • When processing step 3. DSM, Orthomosaic and Index, the points belonging to the group Disabled are not used.
  • If the DSM is generated before assigning points of the point cloud to the disabled point group, step 3. DSM, Orthomosaic and Index needs to be computed again to compute volumes based on the edited point cloud.
12. Exit the editing mode by clicking again the button Edit Densified Point Cloud in the toolbar.
13. In the menu bar, click Project > Save Project.
14. Export the new densified point cloud that was just edited. For more information: How to export the Point Cloud.
9 out of 14 found this helpful
8 comments
  • Pedro Olivares
    Hello. Thank you very much for your time. I have the following issue: I already processed 1; Initial Processing and 2; Point Cloud and Mesh, I already generated and loaded the point cloud, but the "Edit Densified Point Cloud" Tool is not accesible, I am not able to click on it and activate it. What could be that Im not doing, or doing wrong?
  • Marco (Pix4D)
    Dear Pedro,
    It might be because you were working on some other feature/functionality (drawing a polyline for example) that impede you to use the Edit Densified Point Cloud function.
    Try to press "Esc" to exit your current activity this should enable the Edit Densified Point Cloud tool.
    If it does not work, could you please provide a screenshot of your issue?
    Thank you,
    Regards,
    Marco
  • Pedro Olivares
    Hello! Is there any way to "undo" an edit in the raycloud if I already assign the points to "disabled" ?
    Thank you
    Regards,
    Pedro
  • Holden (Pix4D)
    Hi Pedro. There is no undo for pointcloud edits. You can reclassify the points back to the desired group to undo any unintended changes.
  • Jan Stunt
    I have the same problem.  (tool not available)
    Thanks for the help !
    Screenshot :
  • Christina (Pix4D)
    Hi Jan,
    Have you followed Marco´s suggestion of clicking the "Esc" button to exit your current activity? This should enable the Edit Densified Point Cloud tool.
  • setia consultora
    MI MOSAICO SALE CON MUCHAS CRETAS ALREDEDOR DE LOS TEJADOS...... TRATARE DE EDITAR PERO CREO QUE TOMARA BASTANTE TIEMPO... DE ACUERDO AL INFORME EXISTE UN BUEN TRASLAPE Y LAS FOTOS ESTÁN BIEN CLARAS... NO SE SI ESTO OCURRE POR USAR UN TRIAL O ALQUILANDO UNA LICENCIA EL PROCESO MEJORA. SALUDOS
    MY MOSAIC COMES OUT WITH MANY HOLES AROUND THE ROOFTOPS ...... I WILL TRY TO EDIT BUT I THINK IT WILL TAKE ENOUGH TIME ... ACCORDING TO THE REPORT THERE IS A GOOD TRANSFER AND THE PHOTOS ARE WELL CLEAR ... I DO NOT KNOW IF THIS OCCURS BY USING A TRIAL OR RENTING A LICENSE THE PROCESS IMPROVES. REGARDS
  • Holden (Pix4D)
    Hola Setia,
    Es posible que desee considerar el uso de la herramienta Carve para automatizar parte de la eliminación de puntos. Vea el artículo en el siguiente enlace. De lo contrario, puede abrir una solicitud de soporte para obtener consejos específicos.
    https://support.pix4d.com/hc/en-us/articles/212262883-What-is-Carve-
    You may want to consider using the carve tool to help automate some of the point removal. See the article at the link below. Otherwise you can open a support request to get specific advice.
    Edited by Holden (Pix4D)
