The default processing options of each template (Processing Options Default Templates) usually give high quality results. Therefore, in most projects, there is no need to modify the processing options. The processing options should be modified in case:
- It is needed to modify the output result files (types and format).
- Some processing options need to be adjusted to improve the quality of the results.
To open the pop-up window Processing Options, on the Menu bar, click Process > Processing Options...
