How to generate the Contour Lines using the DSM generated in Pix4Dmapper with ArcGIS
Pix4Dmapper can generate contour lines. For more information: 202558469.
In order to generate contour lines with ArcGIS:
1. Open ArcGIS.
2. Import the DSM: 202559669.
3. Open the ArcToolbox.
4. Choose Spatial Analyst tools.
5. Choose Surface.
6. Choose Contour.
For more information: ArcGIS help.
In order to Improve visually the contour lines :
Delete small lines
Depending on the area and its elevation, some tiny contours might be generated (see picture below).
To remove automatically the tiny contours and get a better visual result:
1. Right click the contour lines .shp file.
2. Choose Open Attribute table.
3. If there is no length field, create one: on the Menu, click Table options > Add field.
The new field should appears as in the following image:
4. Right click the length field.
5. Select Calculate Geometry.
6. On the Property field, select Length.
7. Close the table.
8. On the Editor toolbar, select Editor > Start Editing.
9. On the Menu, select  Selection > Select by attribute.
10. Choose a length value. All the contours that have length below this value will be selected.
11. Delete the selected lines.
12. On the Editor toolbar, select Editor > Save Edits.
13. On the Editor toolbar, select Editor > Stop Editing.
Smooth contour lines
 The contour lines are often sharp and need to be smoothed. This can be done in ArcGIS following:
1. Open ArcToolbox.
2. Choose Cartography Tool.
3. Choose Generalization.
4. Choose Smooth Line.
Edit the symology
To edit the symbology of the contour lines: 202559729.
0 out of 0 found this helpful
Powered by Zendesk
