How to merge the Orthomosaic or DSM tiles with Quantum GIS
When the area of interest is very big and the amount of data is large, multiple Pix4Dmapper projects can be created for one area. To merge the orthomosaics that are generated from the multiple projects, an external GIS software like Quantum GIS can be used:
Important: The projects must be georeferenced with GCPs in order to have the same accurate georeference. For more information about the use of GCPs: 202557489.
In order to merge the different GeoTiff orthomosaic files in Quantum GIS:
1. Open Quantum GIS.
2. On the Menu bar, click Raster > Miscellaneous > Merge.
3. In Input files, click Select and select the tiles to merge and click Open (Use the shift key in order to select all).
4. In Output files, click Select and type the name of the output mosaic / DSM and set as format GeoTIFF, choose where to save the new merged file.
5. (only for DSM) activate the No data value box and type -10000.
6. Select the option Load into canvas when finished in order to see the merged file once it is generated.
7. Press OK.
3 out of 3 found this helpful
Powered by Zendesk
