The software is highly parallelized and takes advantages of multi-core CPUs, as well as MMX/SIMD instructions and NVIDIA GPU Cuda processing. However, the different steps of the processing do not use the resources the same way, and not all parts can take advantages of multi-core or Cuda.
Step 1 | |||
CPU | RAM | Hard Disk | GPU |
Most important component.
In some sub-processing steps all the available CPU resources will be used whereas in others not all the CPU is used*. |
Low usage. | Low usage. | (optional) Medium/high usage. |
Step 2 | |||
Fully used. This step will use all the CPU resources available. |
Fully used. This step will use all the RAM resources available. |
Low usage. | Low Usage |
Step 3 | |||
Low usage. | High usage. | Most important component.
The speed of the Hard Disk defines the processing speed. |
No usage. |
rayCloud | |||
Low usage. | Low usage. | Low usage. | Most important component. |
*Some parts of the processing cannot be paralleled and some of them do not consume a lot of resources. However, they need to be completed in order to start the next processing process.
Dear Sir/Madam,
I want to subscribe for monthly Pix4DMapper to process images I took with my drones. I do not have a stronger computer, can I rent a processing cloud on or through Pix4D website? If so, could you please let me know the details and all costs?
Thanks.
Zaki
Dear Zaki,
it is possible to purchase a Pix4Dcloud license that will give access to processing online. For more information see Pix4D store and Pix4Dcloud documentation.
Best
