Hardware components usage during processing - PIX4Dmapper
This article explains how PIX4Dmapper utilizes each hardware component at each processing step
Information:
The software is highly parallelized and takes advantage of multi-core CPUs, as well as MMX/SIMD instructions and NVIDIA GPU Cuda processing. However, the different steps of the processing do not use the resources the same way, and not all parts can take advantage of multi-core or CUDA.
Step 1
CPU RAM Hard Disk GPU
Most important component.
In some sub-processing steps all the available CPU resources will be used whereas in others not all the CPU is used*.
Low usage. Low usage. (optional) Medium/high usage.
Step 2
Fully used. This step will use all the CPU resources available.
Fully used. This step will use all the RAM resources available.
Step 3
Low usage. High usage. Most important component.
The speed of the Hard Disk defines the processing speed.
No usage.
Ray Cloud
Low usage. Low usage. Low usage. Most important component.
*Some parts of the processing cannot be paralleled, and some of them do not consume a lot of resources. However, they need to be completed in order to start the next processing process.
