Can multiple users use the same or different licenses in one computer? - PIX4Dmapper
This article explains that multiple users can use the same license with one device. Multiple users can also use different licenses with one device.
A seat of PIX4Dmapper license is assigned to a computer, laptop, device.
If multiple users wish to use the same computer with the same license, they should log in to PIX4Dmapper using the license email credentials of the license they would like to use. Once the computer is activated, the computer will occupy a seat under the license. Once the computer is activated, multiple users can use the same license.
If multiple users wish to use different licenses on the same computer, they should log in to PIX4Dmapper. Select their desired license. Once they finish using PIX4Dmapper, they can log out from the computer. The next user can then log in to use their desired license.
For step-by-step instructions about how to download, install and activate PIX4Dmapper: Software Download and Installation. The latest version of PIX4Dmapper can be downloaded here: Technical release notes - PIX4Dmapper.
1 out of 3 found this helpful
2 comments
  • Paul Suthard
    I have PIX4D on my computer at work with a yearly cloud license for mapper and due to the virus outbreak I need to work from home.  Can I use PIX4D on my home computer using the registered email and password I use here at work?
  • Avatar
    Momtanu (Pix4D)
    Hi Paul,
    Yes, you can. You might have a device or 2 device license, the licenses are all floating. It means you will need to log out of one device to use in another. You can remotely deactivate a device: https://support.pix4d.com/hc/en-us/articles/115004974006-How-to-remotely-deactivate-a-device. If for some reason, you cannot, you can reach out to us via a support ticket and we could deactivate the device for you.
