When merging individual projects that have Manual Tie Points and/or GCPs:
- GCPs that have the same label and coordinates in the individual projects will be treated as identical in the merged project.
- GCPs/MTPs that have the same coordinates but different label in the individual projects will be treated as identical in the merged project.
- GCPs that have the same label but different coordinates in the individual projects will not be treated as identical in the merged project.
- GCPs that have the same label and coordinates but different type in the individual projects will be treated as identical in the merged project.
- When merging individual projects that have Manual Tie Points with the same label, the following message will appear:
Click:
- Yes: To treat them as identical and to merge all the Manual Tie Point marks from both projects.
- No: To not treat them as identical. No should be selected if the same label has been given to different points in the individual projects.
- When merging individual projects that have Manual Tie Points and GCPs with the same label, the following message will appear:
Click:
- Yes: To treat them as identical (with GCP type) and to merge all the marks from both projects.
