At the moment it is not possible to add images to an existing project.
In order to add additional images:
- If the amount of new images can cover certain area with good overlap between them and on their own they can produce results:
It is possible to process the new images as a new project and then once completed the step 1. Initial Processing, merge the sub project with the original project following. For more information: Merging projects.
- If the amount of new images cannot cover certain area with good overlap between them and on their own they can produce results:
It will be needed to create a new project with all the images. For more information: Getting Started Index.
