Transparency of the orthomosaic
Pix4Dmapper generates two types of orthomosaics:
  • project_name_mosaic_group_name: Orthomosaic with the type and number of bands of the input images. To generate this orthomosaic, select GeoTIFF Without Transparency in the Processing Options. For more information about this option: Menu Process > Processing Options... > 3. DSM, Orthomosaic and Index > DSM and Orthomosaic.
  • project_name_transparent_mosaic_group_name (generated by default): Orthomosaic with one extra band (transparency band), which results in a transparent background of the orthomosaic.
Example: For example, if the input images are TIFF of 6 bands/16 bit float, the project_name_mosaic_group_name will be of 6 bands/16 bit float and the project_name_transparent_mosaic_group_name of 7 bands/16 bit float.
The difference is the following:
project_name_mosaic_group_name gives a black color value to the no value data pixels. project_name_transparent_mosaic_group_name does not display color information (it applies a transparent band) to the no value data pixels.
25 out of 38 found this helpful
2 comments
  • Julien Da Silva Martins
    Hi,
    Sorry in advance for my english mistakes.
    I don't understand, i already have orthomosaïc with a name like this : project_name_transparent_mosaic_group_name
    However, when i insert my mosaic in Autocad, my worthless data pixels is black and not transparent as announced.
    Have you ever seen this problem ?
    Thank's for any answer.
    V. Navarra.
  • Avatar
    Beata (Pix4D)
    Hi Vincent,
    If you doubt that the generated ortho has the transparency included you can double-check it in QGIS. However, I believe the issue requires readjustments of the settings in AutoCAD. Check this instruction; hopefully, it will fix it.
    Regards
