Index > Interface > Menu Project > GCP/MTP Manager... | Previous | Next |
This section contains a GCP/MTP Table which displays all the GCPs/MTPs/Check Points of the projects together with their properties, and 6 action buttons:
- Import GCPs...: Allows the user to import a file with GCPs/Check points.
- Export GCPs...: Allows the user to export GCPs/Check Points coordinates and, optionally for GCPs, the accuracy of the coordinates.
- Add Point : Allows the user to manually add one by one GCPs/MTPs/Check Points.
- Remove Points : Allows the user to remove the selected GCPs/MTPs/Check Points.
- Import Marks...: Allows the user to import a file which contains, for each GCPs/MTPs/Check Points list of the marked images and, for each image, the coordinates and zoom level.
- Export Marks...: Allows the user to export a file which contains, for each GCPs/MTPs/Check Points list of the marked images and, for each image, the coordinates and zoom level.
In the bottom left side, a status text appears indicating how many GCPs are implemented in the project and marked in at least 2 images.
