Index > Interface > Menu View > Index Calculator > Sidebar | Previous | Next |
The Reflectance Map is a tool in PIX4Dmapper to produce a map, where the value of each pixel faithfully indicates the reflectance of the object. This article explains this tool and how to create a Reflectance Map in PIX4Dmapper.
On the left part of section 1. Reflectance Map, there is an arrow that allows the user to show/hide the section by clicking on it:
By default section 1. Reflectance Map is visible.
Section 1. Reflectance Map is not visible.
And the buttons
- Generate: Generates the Reflectance Map if not generated.
- Help: Opens the PIX4Dmapper help.
The section 1. Reflectance Map also displays information for each band of the generated Reflectance Map(s) for each group of images. The following information is displayed:
- Band: Name of the band. If more than one group exists and the same band name exists in different groups, the bands are displayed as "Groupname_band."
- Min: Minimum pixel value per band.
- Avg: Average pixel value per band.
- Max: Maximum pixel value per band.
- Stdev: Standard deviation of pixel values per band.
- Var: Variance of pixel values per band.
If the Reflectance Map(s) are not generated, it displays: "Reflectance Map not yet generated."
Reflectance Map not generated | Reflectance Map generated |
