Index > Interface > Menu View > Index Calculator > Sidebar | Previous | Next |
On the left part of section 1. Reflectance Map, there is an arrow that allows the user to show/hide the section by clicking on it:
By default section 1. Reflectance Map is visible.
Section 1. Reflectance Map is not visible.
And the buttons
- Generate: Generates the Reflectance Map if not generated.
The section 1. Reflectance Map also displays information for each band of the generated Reflectance Map(s) for each group of images. The following information is displayed:
- Band: Name of the band. If more than one group exists and the same band name exists in different groups, the bands are displayed as "Groupname_band."
- Min: Minimum pixel value per band.
- Avg: Average pixel value per band.
- Max: Maximum pixel value per band.
- Stdev: Standard deviation of pixel values per band.
- Var: Variance of pixel values per band.
If the Reflectance Map(s) are not generated, it displays: "Reflectance Map not yet generated."
Reflectance Map not generated | Reflectance Map generated |
