Index > Interface > Menu Project | Previous | Next |
The GCP/MTP Manager pop-up has the following 3 sections:
- GCP Coordinate System: Section to select the coordinate system on which the GCPs/MTPs/Check Points position are based.
- GCP/MTP Table: Section to:
- Import, edit, add and remove GCPs/MTPs/Check Points
- Export GCPs/Check Points coordinates and, optionally for GCPs, the accuracy of the coordinates.
- Import or export a file with the image coordinates of the GCPs/MTPs/Check Points and on which images have been marked, in which position and at which zoom level.
- GCP/MTP Editor: Section to mark the GCPs/MTPs/Check Points on the images.
And the action buttons:
- OK: Confirms the changes.
- Cancel: Does not save the changes.
