Index > Interface > Menu Process | Previous | Next |
This process generates a new Quality Report that refers to the new reconstruction obtained after applying changes to the project once step 1. Initial Processing has been completed. Such changes can be:
- Adding GCPs.
- Adding Manual Tie Points.
- Adding Check Points.
- Changing coordinate systems.
- Enabling/disabling images.
- Running the Rematch and Optimize option.
Clicking the "Generate quality report..." menu item does not tell me where to find the resulting report or give me any other diagnostics.
Hello Grant,
The Quality Report(QR) is stored in .pdf format at ...\1_initial\report.
It opens automatically after any computation. In case you have reoptimized and applied "Generate quality report" afterward, you can either open the .pdf file or go to "Process->Quality Report" within Pix4D.
Regards.
