Menu View > Index Calculator > Sidebar > 5. Export
Index > Interface > Menu View > Index Calculator > Sidebar  Previous  |  Next
Access: On the Menu bar, click View > Index Calculator (available once step 1. Initial Processing has been completed). The Index Calculator sidebar is displayed on the right of the main window. For information about the sidebar's display possibilities: Displaying bars.
On the left part of section 5. Export, there is an arrow that allows the user to show/hide the section by clicking on it:
  •  By default the 5. Export is expanded and visible.
  •  Section 5. Export is collapsed and hidden.
  • Index Values and Rates as Polygon Shapefiles (.shp) with Grid Size [unit/grid]
    Exports the classes as a .shp file (polygon and grid) based on the selected Processing OptionsMenu Process > Processing Options... > 3. DSM, Orthomosaic and Index > Index Calculator. One shapefile will be exported for each Region. This file can be imported directly into the tractor's displays for field (fertilizer) application.
  • Colored Index Map GeoTIFF (.tif) and GeoJPG (.jpg)
    Exports a Colored Index Map that is generated by applying the defined coloring rules to the Index Map. It is a raster file with RGB values. A single Colored Index Map will be exported for all the regions in 3 formats: .jpg, .tiff and .kml.
  •  Upload Reflectance Map to MicaSense Atlas
  • Uploads the necessary reflectance maps for further processing on the MicaSense Atlas platform.
Note: MicaSense Uploader needs to be installed on the computer in order to upload to MicaSense Atlas.
2 out of 10 found this helpful
2 comments
  • Elizabeth Eastman
    After I export the index map and import it into ArcGIS, how do I identify temperature values from each pixel? I am having trouble understanding the attribute table I am viewing.
  • Avatar
    Momtanu (Pix4D)
    You can get the temperature value of each pixel if you import the tif file (index map geotiff) to QGIS from Pix4DMapper. It also gets generated automatically, you will find it in the index folder. You can then use the information tool in QGIS.
    If you use the shp file from Pix4D, it is a actually zonation map and is based on dividing the map into classes/ zones (example from an RGB project but the concept is the same)
    The map has been divided into 5 zones. Here is 6.85 means, the minimum index value of the polygons above is 6.85. You can also change the color (symbology) in QGIS to visualize the zones
    So, in your attribute table, it means polygon 1-5 have 5 degree celcius as the minimum temperature (ranging from 5-13.68)
    Edited by Momtanu (Pix4D)
