Index > Interface > Menu View > Index Calculator > Sidebar | Previous | Next |
On the left part of section 3. Index Map, there is an arrow that allows the user to show/hide the section by clicking on it:
By default section 3. Index Map is visible.
Section 3. Index Map is not visible.
An Index Map is a single band image where each pixel value is computed using a mathematical formula combining the band information of the Reflectance Maps.
- Name: List of available indices. The icon shown before the index name is:
The index exists in the Pix4Dmapper index database.
For more information about the Pix4Dmapper index database list: Pix4Dmapper Index Database List. -
The index was created / edited by the user in this project.
The index was created / edited by the user in another project (on the same computer) that was closed and saved.
- Formula: Displays the formula associated with the selected index.
Formula Status icon: Next to the Formula there is an icon:
The formula is valid.
The formula is incomplete or contains undefined band names.
- Index Status icon: If next to the Generate button there is
The index has been generated.
Edit...: Grayed out when the selected index belongs to the Pix4Dmapper database. Enabled when the selected index was created by the user. Opens the Index Maps window that allows the user to edit the formula that corresponds to the selected index.
For detailed information: Menu View > Index Calculator > Sidebar > 3. Index Map > Index Map (Formula Editor).
- Indices...: Opens up the Index List window which displays the existing indices and allows the user to add, edit, or remove indices. For detailed information: Menu View > Index Calculator > Sidebar > 3. Index Map > Index List.
- Generate: Generates a single band GeoTiff image. Each pixel's value is computed by applying the formula to the corresponding pixel of the Reflectance Map(s). It is grayed out if the user-defined index formula is not valid.
The section 3. Index Map also displays information about the generated index band. The following information is displayed:
- Band: The Index Map has only one band to be displayed (band1).
- Min: Minimum pixel value.
- Avg: Average pixel value.
- Max: Maximum pixel value.
- Stdev: Standard deviation of pixel values.
- Var: Variance of pixel values.
If the selected index has not been generated, it displays: "Selected idex map not yet generated."
Index Map not generated | Index Map generated |
If you have drawn multiple regions on your orthomosaic does the "Avg" under the "Index Map" section express the average over all of the regions or simply the selected region? It appears to not change as you move from region to region however the differences in my particular dataset may just not be large enough to be registered.
David,
It gives you the average of all regions. It might be the average values of the pixels you are adding are kind of the same. The NDVI mean is accumulation when you are adding multiple regions.
If you need an average of one single region (and you have multiple regions)
What you can do is:
Also, If you export all regions together, when you import them, it gets imported together and results in the mean NDVI of all regions
