Index > Interface > Menu View > Index Calculator | Previous | Next |
The Index Calculator Sidebar contains the following sections:
- 1. Reflectance Map: Used to:
- Generate the Reflectance Map(s) used to generate the indices. One Reflectance Map is generated per group of images (RGB, NIR, etc...).
- Displays information about the Reflectance Map(s).
- 2. Regions: Used to:
- Define specific areas that the index calculation will be applied to.
- 3. Index Map: Used to:
- Generate, view, edit indices or select the index to be displayed in the Index View.
- Displays information about the selected index.
- 4. Color Maps and Prescription: Used to:
- Classify the Index Map, based on the indices values.
- 5. Export: Used to:
- Export the index values and prescription rates as polygon shapefiles.
- Export the selected Index Map using the selected classes for the color mapping.
- Upload the Reflectance Map on MicaSense Atlas platform.
