Shortcuts
Index  Previous
The following shortcuts are available:
General shortcuts
Category Action Shortcut Note
Help Open the Pix4D support website F1
Project New project Ctrl + N
Open project Ctrl + O
Save project Ctrl + S Does not save the changes done in the Mosaic Editor
Save project as Ctrl + Shift + S
Exit Ctrl + Q
Basic GCP/Manual Tie Point Editor shortcuts
Preview Remove marked GCP in currently displayed image Del The mouse needs to hover over the image
Zoom out of the image as long as the key is pressed Shift The mouse needs to hover over the image
Zoom in the image as long as the key is pressed Alt The mouse needs to hover over the image
Log output shortcuts
View Open find bar Ctrl + F
Close find bar Esc
rayCloud shortcuts
Layers Sidebar
Tie Points > GCPs/MTPs Rename point F2 A point needs to be selected
Remove point Del A point needs to be selected
Processing Area Remove area Del An area needs to be selected
Objects  Rename object F2 An object needs to be selected
Remove object Del An object needs to be selected
3D View
Viewpoints        View All C
Focus on Selection  An object needs to be selected
Top
Front 1
Back Ctrl + 1
Left 3
Right Ctrl + 3
Home 0
Navigation Modes Standard Ctrl + Y
Trackball Ctrl + T
First Person Ctrl + H
Navigation Modes > Standard            Zoom in +
Zoom in faster Ctrl + "+"
Zoom out -
Zoom out faster Ctrl + "-"
Move forward parallel to the ground plane Arrow Up
Move forward parallel to the ground plane faster Ctrl + Arrow Up
Move backward parallel to the ground plane Arrow Down
Move backward parallel to the ground plane faster Ctrl + Arrow Down
Move up Page Up
Move up faster Ctrl + Page Up
Move down Page Down
Move down faster Ctrl + Page Down
Rotate view down 8
Rotate view down faster Ctrl + 8
Rotate view up 2
Rotate view up faster Ctrl + 2
Rotate view left 4
Rotate view left faster Ctrl + 4
Rotate view right 6
Rotate view right faster Ctrl + 6
Navigation Modes > Trackball Zoom in +
Zoom out -
Navigation Modes > First Person Move forward W
Arrow Up
Move backward S
Arrow Down
Move left A
Arrow Left
Move right D
Arrow Right
Move up Page Up
Move down Page Down
Look up I
Look down K
Look left J
Look right L
Perspective/Orthographic Switch between perspective and orthographic projection 5
Point cloud density Increase point density Alt + "+" Decreases the number of points visible (improves performance on slow computers)
Decrease point density Alt + "-" Increases the number of points visible (requires better computers)
Edit Densified Point Cloud Delete points Del Must be in Edit mode and points must be selected
Select all Ctrl + A Must be in Edit mode
Clear selection Ctrl + C Must be in Edit mode
Invert selection Ctrl + I Must be in Edit mode
Right Sidebar
Images section Focus on selection P The mouse needs to hover over the image or the image needs to be selected
Pop up and maximize thumbnail Space Maximizes the image under the mouse cursor. Pressing Space again docks the image again keeping the new point of view. Pressing Escape docks the image and keep previous point of view.
Volumes shortcuts
The shortcuts of the Processing Area and the Objects layers of the Layers section of the sidebar and the shortcuts of the 3D View are the same as in the rayCloud: Shortcuts.
Mosaic Editor shortcuts
Insert Cell  Insert a new cell after having added the last vertex.InsThe insert Cell mode needs to be activated and the vertices need to be created / marked
View
View     Show Mosaic Ctrl + 1 If several mosaics are generated because of multiple image labels, the shortcut number is incremented by the number of mosaics - 1. For example, if two mosaics are generated, the shortcut to display the second mosaic is Ctrl + 2
Show DSM Ctrl + 2 If several mosaics are generated because of multiple image labels, the shortcut number is incremented by the number of mosaics - 1. For example, if two mosaics are generated, the shortcut to display the DSM is Ctrl + 3
Show Region Ctrl + 3 If several mosaics are generated because of multiple image labels, the shortcut number is incremented by the number of mosaics - 1. For example, if two mosaics are generated, the shortcut to display the regions is Ctrl + 4
Show Edited Mosaic Ctrl + 4 If several mosaics are generated because of multiple image labels, the shortcut number is incremented by the number of mosaics - 1. For example, if two mosaics are generated, the shortcut to display the edited mosaic is Ctrl + 5
Show Mosaic Area Ctrl + 5 If several mosaics are generated because of multiple image labels, the shortcut number is incremented by the number of mosaics - 1. For example, if two mosaics are generated, the shortcut to display the mosaic area is Ctrl + 6
Show Mosaic Tiles Ctrl + 6 If several mosaics are generated because of multiple image labels, the shortcut number is incremented by the number of mosaics - 1. For example, if two mosaics are generated, the shortcut to display the mosaic tiles is Ctrl + 7
Right Sidebar
Right Sidebar Mosaic Editing 1
Visualization 2
Draw region F2 Start drawing a region. Like clicking on the Draw button
Finish drawing region Right Click End drawing a region and insert it in the list
Cancel region drawing Esc
Index Calculator
View View the whole map C
Delete the selected region or region vertex Del The region/region vertex must be selected and the option Lock Regions must be deselected
Index  Previous
2 out of 2 found this helpful
4 comments
  • michel sokulski
    perfeito app
  • Beata (Pix4D)
    Obrigada pelo seu feedback!
    Edited by Beata (Pix4D)
  • Tomas Jönsson
    Hi, It would be nice to have some more short cuts.
    When we do projects with more than 1500 cameras (pictures) sometime some of the cameras (pictures) gets Uncalibrated because the drone makes a big turn an takes a few photos of the horizon. These pictures needs to be disabled in the project.
    When there are a lof of those, the job would get much faster done with a short cut for the Disable-button. Also an option to bulk-disable Uncalibrated pictures would be good to have.
    Eg, "Mark all Uncalibrated cameras" -> Disable.
  • Marco (Pix4D)
    Hi Tomas,
    You might be interested into this option:
    How-to-remove-Images-from-a-Project
    Anyway your request will be shared with our development team.
    Thank you,
    Best
