The following shortcuts are available:
General shortcuts
Category |
Action |
Shortcut |
Note |
Help |
Open the Pix4D support website |
F1 |
Project |
New project |
Ctrl + N |
Open project |
Ctrl + O |
Save project |
Ctrl + S |
Does not save the changes done in the Mosaic Editor |
Save project as |
Ctrl + Shift + S |
Exit |
Ctrl + Q |
Basic GCP/Manual Tie Point Editor shortcuts
Category |
Action |
Shortcut |
Note |
Preview |
Remove marked GCP in currently displayed image |
Del |
The mouse needs to hover over the image |
Zoom out of the image as long as the key is pressed |
Shift |
Zoom in the image as long as the key is pressed |
Alt |
Log output shortcuts
Category |
Action |
Shortcut |
Note |
View |
Open find bar |
Ctrl + F |
Close find bar |
Esc |
rayCloud shortcuts
Category |
Action |
Shortcut |
Note |
Layers Sidebar |
Tie Points > GCPs/MTPs |
Rename point |
F2 |
A point needs to be selected |
Remove point |
Del |
Processing Area |
Remove area |
Del |
An area needs to be selected |
Objects |
Rename object |
F2 |
An object needs to be selected |
Remove object |
Del |
3D View |
Viewpoints |
View All |
C |
Focus on Selection |
F |
Top |
7 |
Front |
1 |
Back |
Ctrl + 1 |
Left |
3 |
Right |
Ctrl + 3 |
Home |
0 |
Navigation Modes |
Standard |
Ctrl + Y |
Trackball |
Ctrl + T |
First Person |
Ctrl + H |
Navigation Modes > Standard |
Zoom in |
Zoom in faster |
Ctrl + "+" |
Zoom out |
Zoom out faster |
Ctrl + "-" |
Move forward parallel to the ground plane |
Arrow Up |
Move forward parallel to the ground plane faster |
Ctrl + Arrow Up |
Move backward parallel to the ground plane |
Arrow Down |
Move backward parallel to the ground plane faster |
Ctrl + Arrow Down |
Move up |
Page Up |
Move up faster |
Ctrl + Page Up |
Move down |
Page Down |
Move down faster |
Ctrl + Page Down |
Rotate view down |
8 |
Rotate view down faster |
Ctrl + 8 |
Rotate view up |
2 |
Rotate view up faster |
Ctrl + 2 |
Rotate view left |
4 |
Rotate view left faster |
Ctrl + 4 |
Rotate view right |
6 |
Rotate view right faster |
Ctrl + 6 |
Navigation Modes > Trackball |
Zoom in |
Zoom in faster |
Ctrl + "+" |
Zoom out |
Zoom out faster |
Ctrl + "-" |
Navigation Modes > First Person |
Move forward |
W Arrow Up |
Move backward |
S Arrow Down |
Move left |
A Arrow Left |
Move right |
D Arrow Right |
Move up |
Page Up |
Move down |
Page Down |
Look up |
I |
Look down |
K |
Look left |
J |
Look right |
L |
Perspective/Orthographic |
Switch between perspective and orthographic projection |
5 |
Point cloud density |
Increase point density |
Alt + "+" |
Decreases the number of points visible (improves performance on slow computers) |
Decrease point density |
Alt + "-" |
Increases the number of points visible (requires better computers) |
Edit Densified Point Cloud |
Delete points |
Del |
Must be in Edit mode and points must be selected |
Select all |
Ctrl + A |
Must be in Edit mode |
Clear selection |
Ctrl + C |
Invert selection |
Ctrl + I |
Right Sidebar |
Images section |
Focus on selection |
P |
The mouse needs to hover over the image or the image needs to be selected |
Pop up and maximize thumbnail |
Space |
Maximizes the image under the mouse cursor. Pressing Space again docks the image again keeping the new point of view. Pressing Escape docks the image and keep previous point of view. |
Volumes shortcuts
The shortcuts of the Processing Area and the Objects layers of the Layers section of the sidebar and the shortcuts of the 3D View are the same as in the rayCloud: Shortcuts.
Mosaic Editor shortcuts
Insert Cell Insert a new cell after having added the last vertex.InsThe insert Cell mode needs to be activated and the vertices need to be created / marked
Category |
Action |
Shortcut |
Note |
View |
View |
Show Mosaic |
Ctrl + 1 |
If several mosaics are generated because of multiple image labels, the shortcut number is incremented by the number of mosaics - 1. For example, if two mosaics are generated, the shortcut to display the second mosaic is Ctrl + 2 |
Show DSM |
Ctrl + 2 |
If several mosaics are generated because of multiple image labels, the shortcut number is incremented by the number of mosaics - 1. For example, if two mosaics are generated, the shortcut to display the DSM is Ctrl + 3 |
Show Region |
Ctrl + 3 |
If several mosaics are generated because of multiple image labels, the shortcut number is incremented by the number of mosaics - 1. For example, if two mosaics are generated, the shortcut to display the regions is Ctrl + 4 |
Show Edited Mosaic |
Ctrl + 4 |
If several mosaics are generated because of multiple image labels, the shortcut number is incremented by the number of mosaics - 1. For example, if two mosaics are generated, the shortcut to display the edited mosaic is Ctrl + 5 |
Show Mosaic Area |
Ctrl + 5 |
If several mosaics are generated because of multiple image labels, the shortcut number is incremented by the number of mosaics - 1. For example, if two mosaics are generated, the shortcut to display the mosaic area is Ctrl + 6 |
Show Mosaic Tiles |
Ctrl + 6 |
If several mosaics are generated because of multiple image labels, the shortcut number is incremented by the number of mosaics - 1. For example, if two mosaics are generated, the shortcut to display the mosaic tiles is Ctrl + 7 |
Right Sidebar |
Right Sidebar |
Mosaic Editing |
1 |
Visualization |
2 |
Draw region |
F2 |
Start drawing a region. Like clicking on the Draw button |
Finish drawing region |
Right Click |
End drawing a region and insert it in the list |
Cancel region drawing |
Esc |
Index Calculator
Category |
Action |
Shortcut |
Note |
View |
View the whole map |
C |
Delete the selected region or region vertex |
Del |
The region/region vertex must be selected and the option Lock Regions must be deselected |
perfeito app
Hi, It would be nice to have some more short cuts.
When we do projects with more than 1500 cameras (pictures) sometime some of the cameras (pictures) gets Uncalibrated because the drone makes a big turn an takes a few photos of the horizon. These pictures needs to be disabled in the project.
When there are a lof of those, the job would get much faster done with a short cut for the Disable-button. Also an option to bulk-disable Uncalibrated pictures would be good to have.
Eg, "Mark all Uncalibrated cameras" -> Disable.
Hi Tomas,
You might be interested into this option:
How-to-remove-Images-from-a-Project
Anyway your request will be shared with our development team.
Thank you,
Best
Hi, I agree there should be more shortcuts.
Thanks!
Hi Ryan. Thanks for sharing your thoughts. Consider sharing your feedback with our developers by posting in the product feedback section of the community.
https://community.pix4d.com/c/feature-request
Pix4D is wicked cool man! This program is WILD!!! If anything could make Pix4D any better, maybe custom keyboard shortcuts? I would really appreciate that! Because the Right Sidebar, where the images are, you have to press the letter "P" to zoom in. The letter "Z" would be better because we could hit the space bar and zoom in to the point of interest using the same hand. Also, that zoom feature would be awesome if it focused on the position of the mouse rather than the green X. Please make this happen! We want to scroll in as little as possible! If this shaved off 1 second per image, this could literally cut 3,000 to 5,000 seconds, or 45 to 90 minutes of processing time! That means, one hour less time on your servers!
You're great at what you do! Thanks!
Hi Richard,
