Index > Interface > Menu Project > Image Properties Editor... | Previous | Next |
This table is used to describe and edit the information and the status of the images used for the project.
The following actions can be performed on the table:
The table has as many rows as the amount of images in the project. Each row displays information for one image:
- Status of the image (Enabled)
- Image
- Group
- Camera model (Multi-camera model projects)
- First coordinate
- Second coordinate
- Third coordinate
- Accuracy Horz
- Accuracy Vert
- Omega
- Phi
- Kappa
Sorting the table | ||||
By clicking the column Image, the title will be used to sort the table, it will be ordered from the smallest to the highest value. By clicking again the column, the title already used for sorting, will be switched from smallest to highest and from highest to smaller and vice versa. A triangle indicates which column title is used for sorting and the type of sorting:
Selecting images | ||||
Selecting an image Left click any of the image's cells. The row corresponding to the selected image is displayed in blue. |
Selecting multiple images For images that are displayed one after the other: Press the Shift key and left click the first and last images to be selected. The rows corresponding to the selected images are displayed in blue. Alternatively, left click one image and while keeping the left button clicked, move the mouse up or down. For images that are not displayed one after the other: Press the Control key and left click all the images to be selected. The rows corresponding to the selected images are displayed in blue. |
Editing values | ||||
Editing one image For the Enabled column: 1. Click the box (the status switch between selected / unselected). For the Group column: 1. Double click the cell. For the Latitude, Longitude, Altitude, Accuracy Horz or Accuracy Vert columns: 1. Double click the cell. |
Editing all the values for one column For the Enabled column: 1. Right click one cell of the column. For the Group column: 1. Right click one cell of the column. For the Latitude, Longitude, Altitude, Accuracy Horz or Accuracy Vert columns: 1. Right click one cell of the column. |
Editing the selected rows values for one column Select multiple images and: For the Enabled column: 1. Right click one of the selected cells of the column. For the Group column: 1. Right click one of the selected cells of the column. For the Latitude, Longitude, Altitude, Accuracy Horz or Accuracy Vert columns: 1. Right click one of the selected cells of the column. |
The status of the image is displayed in the Enabled column. It is defined by a box that indicates if the image is used for the processing or not. If the box is selected, the image is enabled and is used for the processing.
To select or unselect an image: Left click on the box.
This column displays the name of the images. It cannot be edited.
When processing images that belong to different groups, all images are processed together, generating:
- One point cloud of automatic tie points for the whole project. The color of the automatic tie points will be mixed: some points will take color from the RGB images and others from the NIRGB images.
- One densified point cloud per group.
- One DSM for the whole project.
- One orthomosaic per group.
By default the images that have the same number and type of bands as well as the images with the same pixel type (byte, float) will be grouped as group1. Images with different bands and pixel type will be grouped as group2, group3, etc. To change the group of one image, double click on the corresponding cell and edit the group. For more information about editing the group of multiple images: Menu Project > Image Properties Editor... > Images Table.
For projects with more than one camera model, this column displays the camera model assigned to the corresponding images.
To change the camera model of one image, double click on the corresponding cell. Click on the arrow that appears and, from the drop-down list, choose the desired camera model.
The first coordinate is:
- Latitude [degree]: If the coordinate system of the images is a geographic coordinate system.
- X [m]: If the coordinate system of the images is a projected coordinate system. The unit is given in meters.
- X [feet]: If the coordinate system of the images is a projected coordinate system. The unit is given in feet.
- Local X [m]: If the coordinate system is defined by the user (local coordinate system). The unit is given in meters.
The coordinate columns are filled:
- When importing the coordinates from the image EXIF data if the information exists.
- When importing the coordinates from the image geolocation file.
- When manually editing the table: double click on the corresponding cell and enter the coordinate.
The second coordinate is:
- Longitude [degree]: If the coordinate system of the images a geographic coordinate system.
- Y [m]: If the coordinate system of the images is a projected coordinate system. The unit is given in meters.
- Y [feet]: If the coordinate system of the images is a projected coordinate system. The unit is given in feet.
- Local Y [m]: If the coordinate system is defined by the user (local coordinate system). The unit is given in meters.
- When manually editing the table: Double click on the corresponding cell and enter the coordinate.
The third coordinate is:
- Altitude [m]: If the coordinate system of the images is a geographic coordinate system.
- Z [m]: If the coordinate system of the images is a projected coordinate system. The unit is given in meters.
- Z [feet]: If the coordinate system of the images is a projected coordinate system. The unit is given in feet.
- Local Z [m]: If the coordinate system is defined by the user (local coordinate system). The unit is given in meters.
Defines the horizontal accuracy value (Accuracy Horz). The horizontal accuracy refers to the first and second coordinates (latitude, longitude, or X,Y) of the images.
- Very accurate image geolocation (latitude, longitude, or X,Y) coordinates: Low accuracy value.
- Non accurate image geolocation (latitude, longitude, or X,Y) coordinates: High accuracy value.
The higher the accuracy value, the less impact the image's coordinates will have on the Initial Processing, compared to other images or GCPs with lower accuracy values. The accuracy is a value between 0.001 and 10'000.
To edit the horizontal accuracy of one image, double click on the corresponding cell and enter the new value. For more information about editing the horizontal accuracy of multiple images, see Actions on the table.
Defines the vertical accuracy value (Accuracy Vert). The vertical accuracy refers to the third coordinate (altitude or Z) of the images.
- Very accurate image geolocation (altitude or Z) coordinate: Low accuracy value.
- Non accurate image geolocation (altitude or Z) coordinate: High accuracy value.
The higher the accuracy value, the less impact the image´s coordinate will have on the Initial Processing, compared to other images or GCPs with lower accuracy values. The accuracy is a value between 0.001 and 10'000.
To edit the vertical accuracy of one image, double click on the corresponding cell and enter the new value. For more information about editing the vertical accuracy of multiple images, see Actions on the table.
Omega (ω) is the rotation around the Χ-axis. It is given in degrees.
The rotation columns are filled:
- When importing the angles from the image geolocation file.
- When manually editing the table: Double click on the corresponding cell and enter the angle.
This value is optional as Pix4Dmapper does NOT require the orientation of the camera in order to process the projects.
For more information about how Pix4Dmapper defines the Omega - Phi - Kappa angles: How are omega, phi, kappa defined?.
Phi (φ) is the rotation around the Y-axis. It is given in degrees.
Kappa (κ) is the rotation around the Z-axis. It is given in degrees.
Hello, may I ask whether the setting of horizontal precision and vertical precision in the ground control point will affect the accuracy of the 3d model?Looking forward to your reply. Thank you!
Hi,
In general, the settings of the accuracy of GCPs affect the final accuracy of the 3D model. For instance, if your GCPs are measured with an RTK GPS (which usually achieves 2 cm accuracy), you should set the horizontal and vertical accuracy to 2 cm (or 0.02 m). If you set it to 1 m, your final 3D model will not be very accurate. On the other hand, if you set the accuracy to 0.1 cm, you are constraining it too much and the model might not calibrate well. Long story short, the accuracy you set for the GCPs must be first and foremost realistic.
Cheers,
Teodora
I am trying to move a project into a different folder in order to share it. Once I do, the Mosaic Editor can no longer load because it can't find the image database. How can I edit the location of the image database for a project?
Hi Burlyn,
For project sharing, we strongly recommend using the Pix4D Cloud. Please note that Pix4Dmapper works with a fixed folder structure. In order to move a project from one computer to another one, we recommend following the steps here: https://support.pix4d.com/hc/en-us/articles/202559229-How-to-move-a-project-from-one-machine-to-another
Cheers,
Teodora
