Index > Interface > Menu Process | Previous | Next |
This article explains how to save undistorted images when using PIX4Dmapper. This feature is activated once Step 1. Initial Processing has been completed.
This process generates an undistorted copy of each original image using the optimized distortion parameters of the selected camera model.
Original image: The square grid is distorted because of the lens of the camera. | Undistorted image: The square grid is now perfectly aligned. |
When I click the Save undistorted image option, ststus says that is saved. But where is the image saved
Hi!
The Undistorted images are saved in the Result Folder. To find them simply follow this path:
...\project_name\1_initial\images\undistorted_images\image.
If you ever have a problem finding your Pix4D outputs, please have a look at this article. You can find there all paths to each output that you can be generated by Pix4Dmapper.
