Index > Interface > Menu Process | Previous | Next |
Resources | and Notifications |
Allows the user to select the usage of the hardware resources and to select a notification for when processing is done. This can be useful when running multiple projects on the same computer or when the computer is needed for tasks other than processing:
This tab contains two sections:
- Maximum Resources Available for Processing: Allows to throttle the resources dedicated to the software
- Notifications: Allows to trigger a notification when processing is completed.
- RAM [GB]: By default all the available RAM memory is used. It is possible to reduce the amount of RAM assigned to the processing of the project by moving the slider to a lower value.
- CPU Threads: By default all the CPU threads are used. It is possible to reduce the amount of CPU threads assigned to the processing of the project by moving the slider to a lower value.
- NVIDIA CUDA Capable Devices:
- ONLY when using NVIDIA Graphic card(s) compatible with CUDA, it is possible to activate / deactivate the use of the Graphic card(s) by selecting/deselecting the box.
- When using Cuda processing, the processing speed is increased and the impact is more significant for large projects.
- Under NVIDIA CUDA capable devices list, the list of GPUs appears . The cards that have at least 2 GB RAM are selected by default.
NVIDIA CUDA Capable Devices available. |
NVIDIA CUDA Capable Devices not available. |
If the notification box is selected, an email notification will be sent to the email address used to log in Pix4Dmapper when processing is done.
Hi everyone,
My name is Sisva. I'd like to ask you about the NVDIA CUDA capable devices.
I am using NVDIA GeForce GT730 with compute capability is 3.5.
But, when I want to process the project, it is showed that "NVIDIA CUDA Capable Devices not available".
Is there something wrong? Or any drivers that I should installed before?
I'll wait for your responses.
Thank you.
Hi Sisva,
You should have a look on this article:
How-to-update-the-NVIDIA-graphic-card
It explains where to check if your driver version and how to verify if it is updated or not.
Here is the latest driver for your graphic card:
https://www.nvidia.com/Download/driverResults.aspx/141169/en-us
Best,
Hi Marco,
Thank you for your response.
For your information the operating system that I am using is Windows Server 2012 R2.
And when I search the driver, i couldn't find the driver that compatible with my OS.
Someone said to me that I could use the NVDIA driver for Windows 8 x64 bit for my Windows Server 2012 R2 x64.
Do you know about this matter?
I just found out now that I've never used the GPU to process the project because the GPU that I have is not detected.
Thank you.
Hi I am just wondering if it is possible to send the notification to a different email than the one used to log in when processing is finished?
Hi Brian,
Unfortunately, it is not possible. You would need to change the email address of your Pix4D account.
Best
