Index > Interface > Menu View | Previous | Next |
By selecting the Map View the following elements are displayed on the main window:
- Menu bar entry: Displayed on the Menu bar.
- Toolbar: The standard toolbar and some extra buttons related to the Map View.
- 2D View: Displayed in the main window. By default the Satellite view is displayed.
- Status bar: Displayed at the bottom right of the Map View. Displays the coordinates when passing the mouse over the 2D View.
On the Menu bar, when clicking Map View, the following option is displayed:
- Processing Area: Indicates the area of the project for which the different outputs will be generated.
The following toolbar buttons are displayed:
- Standard toolbar buttons: For more information: Interface.
- Toolbar extra buttons:
- View
Zoom In: Zooms in the selected view.
Zoom Out: Zooms out the selected view.
- Change Background Map: A drop-down list that changes the 2D View background displayed on the main window. It has the following options:
- Satellite (default): Displays a satellite view of the project's location. If none of the images is geolocated and there are no GCPs in the project, the whole Earth is displayed.
- Maps: Displays a map view of the project's location. If none of the images is geolocated and there are no GCPs in the project, the whole Earth is displayed. The background map is provided by Mapbox.
Section which displays the location of the project on Earth and the project elements (images, GCPs, etc.). For more information: Menu View > Map View > 2D View.
The coordinates of the current mouse position on the 2D View are displayed at the bottom right of the Map View. Two types of coordinates are displayed:
Geographical WGS84 coordinates |
Latitude and longitude coordinates are displayed. |
Selected Coordinate System |
The X and Y coordinates of the selected output coordinate system (Select Image / GCP / Output Coordinate System ) are displayed . |
[UI]: Yeni Proje tıklandı.
[Uyarı]: Uyarı w9020: GDAL Hatası <1> enlem veya boylam limitleri aştı
[İşlem]: ProjectLoading
[İşlem]: ProjectLoaded
[UI]: İşlem Seçenekleri tıklandı.
[UI]: İşlem Başlat tıklandı.
[İşleme]: Step1Running
causes of these issues
Hi,
Actually, the warning that you see is a warning for the developers. It is not an indicator of good or bad processing. It is something that should be hidden. At the moment, it is misleading for the users. This notice should be investigated only if the user experiences a crash, otherwise, feel free to ignore it. Therefore, did you experience any hard crash? Did the software shut down or freeze? If yes, please submit a ticket to Pix4D Support team and send us the following:
▸ The quality report (.pdf format): ...\project_name\1_initial\report\project_name_report.pdf
▸ The project log file (text file): ...\project_name\project_name.log
▸ The project file (.p4d): ...\project_name.p4d
Regards,
初期処理中にエラーe0094となりました。
改善方法を教えてください
Hi,
In this article Error e0094: It was not possible to initialize OpenGL, you will find solutions to your problem.
Regards
Bonjour,
PIX4D n'affiche plus de fond satellite dans l'interface carte, je souhaiterais savoir si cela vient d'un problème sur mon poste de travail où si cela vient du logiciel.
En vous remerciant,
John CLERIN
This is related to an issue with Mapbox, our basemap provider:
Mapbox basemap issue with older versions of Pix4D’s software
It is solved in our latest version of Pix4Dmapper that you can download here: Pix4Dmapper 4.6.3
