Index > Interface | Previous | Next |
There are 13 items that can be selected:
- New Project...
- Open Project...
- Recent Projects
- Close Project
- Download Project Files...
- Upload Project Files...
- Image Properties Editor...
- GCP/MTP Manager...
- Select Output Coordinate System...
- Save Project
- Save Project As...
- Split into Subprojects...
- Exit
Depending on whether there is a project loaded/created, different options will be enabled or grayed out:
Available options before a project is loaded or created. | Available options once a project is loaded or created. |
Opens the wizard to create a new project.
For step by step instructions about how to create a new project: Step 2. Creating a Project.
Opens an existing project. By clicking Open Project, a pop-up appears to navigate and select a .p4d project file (Pix4Dmapper project file format).
Displays a menu with the 10 last projects that have been opened. By clicking on one of them, the project will open.
Closes the current project.
Allows to download and load a project previously uploaded to Pix4D Cloud. This option is enabled when the software is opened and disabled once a project is loaded or created.
For step by step instructions: How to download / open a previously uploaded project.
Allows to:
For more information: Menu Project > Upload Project Files....
Allows to change the properties of the project's images such as: the coordinate system, the image geolocation, the image geolocation accuracy and the associated camera model. For more information: Menu Project > Image Properties Editor....
Allows to set up and edit the properties of the GCPs / Manual Tie Points / Check Points such as: Select the GCP coordinate system, import GCPs, add / remove points, import / export the marks, open the rayCloud or Basic Editor for marking. For more information: Menu Project > GCP / MTP Manager....
Allows to select the coordinate system of the results. For more information: Menu Project > Select Output Coordinate System....
Saves the status/properties and configuration of the current project.
Save the status/properties, configuration, and results of the current project into another location and/or with a different name.
Allows to automatically split the project into subprojects by creating different .p4d files.
Each .p4d file contains the images for the created subproject.
The different subprojects overlap, therefore, some images will appear in more than one subproject.
By clicking Split into Subprojects... the Split the Project into Subprojects pop-up will open:
It contains the following options:
- Maximum Number of Images: Defines the area to be used to split the terrain into subprojects. When selecting for example 100, a subproject will cover the area from 100 images plus some area and images from neighboring subprojects so as to ensure there will be overlap between them.
- Suffix of the Subproject's Name: Text to use as suffix for the subprojects. Each subproject will be named as projectname + Suffix + Number.
Closes the project and exits the software.
