Index > Interface > Menu View > Mosaic Editor | Previous | Next |
For information about the sidebar's display possibilities: Displaying bars.
The Mosaic Editing sidebar contains the following sections:
- Regions: Allows the user to select, draw or delete regions.
- Images: Allows the user to select which projection and which image can be used for each region.
- Export: Allows the user to:
- Save locally the changes (saves changes in the Mosaic View in internal temporary files).
- Reset the displayed mosaic.
- Export an edited mosaic by exporting the internal temporary files.
Contains the following buttons:
- Region[number]: Available once one region has been drawn. Allows the user to select a region.
- Draw: Allows the user to draw a region. For step by step instructions: How to edit the Orthomosaic.
- Delete: Allows the user to delete the selected region.
- Delete All: Allows the user to delete all the existing regions.
This section:
- Displays the different projections available for the selected region.
- Displays the selected projection type and image for the selected region.
- Allows the user to change the projection type and image to be used for the selected region.
It is possible to select:
- Ortho Projection: displays a list of original images in ortho projection.
- Planar Projection: displays a list of original images in a planar projection.
Allows the user to:
- Export an edited mosaic by exporting the internal temporary files saved.
- Save: Saves the changes in the mosaic: Overwrites only the areas corresponding to the existing regions using the selected projections.
The saved Edited Mosaic will be loaded when opening the project again and when exporting it.
- Reset: Resets the Edited Mosaic with the Generated Mosaic (which is stored in the results folder).
- Export: The selected Edited Mosaic overwrites the Mosaic generated at step 3. DSM, Orthomosaic and Index.
- Help: Opens Pix4Dmapper help.
