Pix4Dmapper 1.1 Technical Release Notes
1.1.23 April 30, 2014 New release
1.1.30 May 13, 2014 Bug fix release
1.1.33 May 22, 2014 Bug fix release
1.1.35 May 26, 2014 Bug fix release
1.1.38 May 28, 2014 Bug fix release
1.1.40 June 17, 2014  Bug fix release
1.1.41 July 8, 2014  Bug fix release
1.1.44 July 28, 2014  Bug fix release
1.1.45 July 29, 2014  Bug fix release
Version 1.1.23
What is new
  • Index Calculator
    The new Index calculator interface allows the user to create meaningful maps from any multi-spectral sensor and customize your NDVI as well as any vegetation index map directly in the software.
    For more information on how to use the Index Calculator: 47826703.
  • Point Cloud Filters
    Create filters based on image content to remove points from the 3D point cloud.
    • Point Cloud Densification Area: Define a 3D area that will be used for the point cloud densification. All points outside that area are removed.
      For more information on how to draw a Point Cloud Densification Area with the rayCloud Editor: 52385303.
      For more information on how to edit a Point Cloud Densification Area with the rayCloud Editor: 52394673.
    • Image Annotation: Annotate the images to remove points from the point cloud.
      For more details on how to annotate images with the rayCloud Editor: 51100278.
      Densified Point Cloud before Image annotation Densified Point Cloud after Image annotation
  • Contour Lines
    Create and export contour lines automatically.
    For more information on how to generate contour lines 55434647.
    Contour Lines of a quarry Contour Lines and DSM of a quarry
  • Automatic improvement of the reconstruction
    The new Rematch and Optimize option allows the user to computes more matches between the images (and therefore more Automatic Tie Points) and reoptimizes the internal and external camera parameters. For more information: 48550678.
  • Generate the Quality Report independently
    Generate a new report once the reconstruction has been manually modified (e.g. adding GCPs). This allows the user to generate the report only once the reconstruction is adequate. For more information: 48550848.
  • Define the horizontal and vertical tolerance for GCPs
    For more information: 27896983.
  • Define the horizontal and vertical tolerance for the images position
    For more information: 28142498.
  • Generate a low resolution orthomosaic at step 1. Initial Processing
    For more information: 27133613.
  • New snapping option when drawing new objects
    It is possible to use existing vertices for the new object being drawn by snapping to them.
Improvements
  • Concepts
    • Change the concept of the label associated to each image to group. One orthomosaic is generated per image group.
    • Rename the project types (for more information: 27133613):
      • Aerial to Aerial nadir
      • Vegetation to Alternative processing mode
      • Oblique to Aerial oblique or terrestrial
  • Inputs
    • New Pix4D file format for importing the image geolocation. Coordinates can be given in (latitude, longitude, altitude), (longitude, latitude, altitude), (X,Y,Z), or (Y,X,Z). For more information: 27311736.
    • Load camera parameters from .p4d project file when the camera model also exists in the camera model database.
  • Outputs
    • Choose the delimiter for XYZ output files. The delimiter can be set to spacetab, comma, or semicolon. For more information: 27345277.
  • Processing
    • Interface switches to a "Read-Only" mode while processing. For more information: 56564096.
    • Alternative processing mode: improved results.
    • Improved speed of the orthomosaic generation within step 3. DSM and Orthomosaic Generation.
    • Improved handling of hundreds of millions of points within step 3. DSM and Orthomosaic Generation.
    • Speed and stability improvements for step 2. Point Cloud Densification.
    • Improved orthomosaic generated using the Weighted Average with Visibility method.
  • Processing options
    • Point cloud densification options: Set the minimum number of matches not only to 3,4, or 5 but also to 5 or 6. For more information: 27417003.
    • Save settings for all processing options as default. For more information: 27133613.
  • Map View
    • Flight plan displayed in the 2D Map. For more information: 27054637.
  • rayCloud Editor
    • Improved interaction with the 3D view in terms of speed and software stability.
  • Mosaic Editor
    • New auto save option. Deactivated by default. When activated allows the user to save the changes in the Mosaic Editor every 5 minutes. For more information: 27130133.
Known bugs
  • It is not recommended to use the merging option for the DSM and orthomosaic for some very large projects.
  • When generating the report from the menu Process > Generate Quality Report, if the Undistorted images option is activated in the Process > Options... > Initial Processing tab, the undistorted images will be generated and will overwrite existing undistorted images.
  • When selecting Process > Save Undistorted Images, the dvp folder located in 1_initial/params is not generated. To generate the file, select the Undistorted images option in the Process > Options... > Initial Processing tab and run step 1.
  • Index Calculator crashes with datasets with image group names containing a space. Workaround: do not use spaces in the image group names.
Version 1.1.30
Improvements
  • Extended camera model database
    • DMC-LX2_6.3_4224x2376
    • GoPro3+ black
    • GoPro3+ silver
    • ILCE-7R_16mmF2.8Fisheye_16.0_7360x4912
    • CanonEOS5DMarkIII_EF50mmf/1.4USM_50.0_5760x3840
  • Processing
      • Save camera parameters files for fisheye lens camera models in 1_initial/params.
      • Improved speed for orthomosaic generation at step 3.DSM and Orthomosaic Generation using the weighted average.
      • Keypoint matches statistics in the report per camera model are visible for projects with multiple camera models.
  • Project merging
    • Copy image annotation when merging projects.
  • Mosaic Editor
    • Improved memory usage (RAM) when blending the mosaic of large datasets using the Mosaic Editor.
    • Improved usage of images in planar projection.
Bug fixes
  • Inputs
    • More stable loading of projects with images in multiple folders and same image name.
    • Fix bug where the image annotation on images with the same file name did not work.
  • Processing
    • Fix bug where GCPs and Manual Tie Points marked in uncalibrated or disabled images where taken into account for the GCP statistics in the Quality Report.
    • Fix bug where the dvp folder located in 1_initial/params is not generated when selecting Process > Save Undistorted Images
    • Fix bug that created artifacts in the orthomosaic tiles at their borders when using the weighted average method to generate the orthomosaic.
  • Index Calculator
    • Fix bug where the Index Calculator crashed with datasets with image group names containing a space.
Known bug
Version 1.1.33
Improvements
    • CanonIXY220F_4.3_4608x3456
  • Processing
    • The merged DSM and orthomosaic GeoTIFF files are not generated if its size exceeds 400 million pixels.
    • Improved calibration when running in Aerial nadir Alternative processing mode.
    • Improve manual camera calibration.
  • Project management
    • Improved project management when changing the location of the project.
  • GCP Editor
    • Import 3D GCPs with their tolerance. The format is gcpName, X, Y, Z, Thorz, Tvert.
  • rayCloud Editor
    • Improved memory management for the rayCloud Editor.
Bug fixes
  • Outputs
    • Fix bug where contour lines in DXF or DGN format could not be opened in AutoCAD.
  • Processing
    • Fix crash at step 1. Initial Processing when the latitude, longitude or X,Y coordinates of the images are all the same.
    • Fix crash when processing an old project with point cloud densification area.
  • Map View
    • Fix bug to display correctly TIFF images when viewing them on double click.
  • GCP Editor
    • Fix bug to display correctly TIFF images.
  • Index Calculator
    • Fix bug where the displayed index values under the mouse cursor were not correct.
Known bug
Version 1.1.35
Improvements
  • Processing
    • Improved memory management for grid DSM generation.
  • Index Calculator
    • Index Calculator available after step 1. It is recommended to run step 2 if the terrain is not flat.
Bug fixes
  • Processing
    • Fix bug where step 1 initial processing was not working on multi-processor computers.
    • Fix bug where the software crashed at step 3 during orthomosaic generation on 8GB / 16GB-RAM systems.
Known bug
Version 1.1.38
Improvements
  • Processing
    • The merged DSM and orthomosaic GeoTIFF files are not generated if its size exceeds 1 Giga pixels.
Known bug
Version 1.1.40
Bug fixes
  • Processing
    • Fix bug where merged GeoTIFF files for the DSM and orthomosaic were not generated.
    • Fix bug where the coordinate system of the point cloud densification / orthomosaic area was wrong when selecting a different output coordinate system.
Known bug
Version 1.1.41
Bug fixes
  • Inputs
    • Fix bug where parsing QuestUAV's flight log did not work.
    • Fix bug where saving as for a processed project failed.
  • Processing
    • Improved alternative mode processing type.
  • Camera models
      • CanonPowerShotSX260HS_4.5_4000x3000
      • New camera models for Phantom 2 Vision and Phantom 2 Vision+:
        • PHANTOMVISIONFC200_5.0_4384x3288
        • PHANTOMVISIONFC200_5.0_4384x2922
        • PHANTOMVISIONFC200_5.0_4384x2466
      • New camera models for GoPro Hero Black Edition and GoPro Hero Silver Edition
Improvements
  • License management
    • Improved license security
Known bug
Version 1.1.44
Bug fixes
  • Processing
    • Fix bug that caused wrong project georeferencing in some projects when using GCPs.
Known bug
Version 1.1.45
Bug fixes
  • Processing
    • Fix bug where merging projects failed when using GCPs.
Known bug
9 out of 9 found this helpful
