Error
Error e0049: Error in the point cloud densification.
Description
Processing step 2 stops with the message:
Cause
This error may come from different sources:
- There is not enough RAM
The project .log file contains the message:
Failed with error (bad allocation)!
This means that the RAM available is not enough for the amount of points generated. This may be due to the number of images, their resolution, the processing options or the available resources.
- The processing area is wrongly defined
The project .log file contains any of the following message:
[Error]: Cannot densify the point cloud! There are 0 points in the densification area!
This means that the Processing Area is defined outside the results of Step 1, and therefore there are no Automatic Tie Points available to be densified.
Solutions
- There is not enough RAM:
The possible solutions are:
1. Use a computer with more RAM.
2. Reduce the number of points generated in the processing options. For step by step instructions: How to change the Processing Options to generate fewer 3D Points.
1. Change the processing options and process again the step 2:
2. In 2. Point Cloud and Mesh, in the Advanced tab, in the Point Cloud Filters section, deselect Use Processing Area.
3. Click OK.
2. Edit the Processing Area so that it includes Automatic Tie Points: How to use a processing area in Pix4Dmapper.
hello
i have one question why pix4d suddenly closed while processing . this type problem occur every day then i again start process but another day pix4d suddenly closed without giving any information. (i almost process 6000 photos)
Hi Tom,
Could you open a ticket with Support and provide us the files listed below? We would need more details to provide assistance in the most efficient way.
▸ The quality report (.pdf format): ...\project_name\1_initial\report\project_name_report.pdf
▸ The project log file (text file): ...\project_name\project_name.log
▸ The project file (.p4d): ...\project_name.p4d
Additionally, please send us the machine specs:
1. Click the Windows Start icon and type System Information. Select the application in the list above.
2. In the application, click File > Save... and export the content.
3. Attach the file your_file.nfo to the reply.
Thank you,
Alice
