Mount and configure a Pix4D supported RTK device - Emlid Reach RX
To effectively use an Pix4D-adapted RTK device with a mobile device, the initial step is configuring the setup correctly. This involves setting the camera offset between the antenna and the mobile device's camera. This offset, whether measured automatically by Pix4Dcatch (SPC+) or manually by the user, is crucial for accurately computing locations captured by Pix4D-adapted RTK devices, ensuring precise measurements for scans or ground control points (GCPs).
Mount the Pix4D-adapted Emlid RTK rover to the Device
Smartphone model
Devices with a Known Camera Offset
Camera Offset Measurements
How to Manually Measure the Camera Offset
Measure the X axis
Measure the Y axis
Measure the Z axis
Enter the Camera Offset Values
Note: Update your RTK antenna firmware before use it to ensure optimal performance and avoid potential issues, it’s crucial to update the firmware of your RTK antenna before using it. Follow the instructions provided in the Emlid Reach RX Firmware Update Guide to complete the update process.
Emlid Reach RX has been fully integrated in PIX4Dcatch since version 2.0.0 released on 30.04.2024.
Mount the Pix4D-adapted Emlid RTK rover to the device
The Pix4D-adapted Emlid is a GNSS RTK receiver that allows PIX4Dcatch to geolocate the images acquired by your mobile device with centimeter accuracy. The Pix4D-adapted Emlid RTK rover can be coupled with mobile phones (iOS) using the SP connectors (cases or clamps) provided by SP Connect.
If the mobile device does not have a custom case available (e.g. Android phones), the universal clamp can be used.
Smartphone model
First, insert the phone into its compatible SP-connect case. Then, mount the case to the device by following the instructions provided with the SP-connect case.
This list contains the combinations of mobile devices (phones and tablets) with the Pix4D-adapted RTK devices where the camera offsets are already measured. PIX4Dcatch will automatically fill in the X, Y, Z fields with the correct camera offset values.
iPhone 16 Pro Max
iPhone 15 Pro Max
When initiating the connection to the Pix4D-adapted RTK devices, the dialog RTK Device Settings opens. The section Camera Offset allows the user to set the X, Y, Z offset values properly. The available options depend on the combination of the Pix4D-adapted Emlid RTK device version, the mobile device and the device case. The following options are available: SPC+ and Custom.
The option SPC+ is only available if the combination of the Pix4D-adapted Emlid RTK device version, the mobile device and the device case are known. The option Custom is always available and intended to be used by universal or specific cases. This option requires measuring the camera offsets manually and setting them in PIX4Dcatch. The camera offset value selection is saved for the next measurements and modifications are only needed if the setup changes.
Mount the device to the Pix4D-adapted RTK devices using the appropriate SP-connect case. Phone cases can be purchased separately from the SP-connect website. The SP-connect universal phone mount can be used if the specific model is unavailable. SP-connect cases are also available in most bicycle and motorcycle shops.
Place the device in landscape mode and the display to the front. Notate the orientation of the X, Y, and Z axes and how they relate to the point of origin on the antenna to measure from. The point of origin resides in the middle of the screw mount at the base of the antenna. It will also be necessary to determine which lens to measure from for devices with multiple camera lenses.
Measure the X and Y axis
To measure the X-axis offset, simply measure the X-axis on the vertical axis from the middle of the antenna to the point where it intersects the Y-axis. Then, measure the distance from the camera lens to the bottom of the mount.
Measure the Z axis
Measure the depth from the center of the handle to the center of the lens for the Z axis offset.
Enter the camera offset values
With the camera offsets properly measured and recorded, they can be included in the appropriate Camera Offset Values field of the RTK Device Settings dialog. Depending on the device's geographical region, centimeters or inches will be the displayed measurement unit.
The camera offset is now properly set in the Camera Offset Values X, Y, Z fields. Continue with the RTK Device Settings dialog to complete the Pix4D-adapted Emlid RTK connection to the device.
