Stitching artifacts - PIX4Dreact
This article discusses the causes of artifacts in orthomosaics.
Graphics card driver issue
This is a common problem. The artifacts look really strange. Many colors are present, and it's a combination of big and small squares, images are scrambled, looking like a Picasso painting.
Example artifacts:
image-20240207-091921   image-20240228-113329
This is commonly related to outdated graphics card drivers. To solve this:
Color balance
Different colors between images can generate a "honeycomb" effect:
Honeycamb_effet
To solve this issue and improve the color transitions in the orthomosaic:
  • Import the images again.
  • Enable Full Blending under Advanced settings - Processing options.
Insufficient overlap
When the overlap is insufficient, processing may fail, or artifacts can occur in the orthomosaic.
1-1
Make sure the overlap is more than 70% for both the side and frontal overlap.
Corrupted images
Non-nadir or distorted images can generate artifacts.
663c4be9-ac3f-48c1-a391-777454db1b03 (1)-1
To solve this issue, inspect the images around the area and discard them when processing.
Buildings are not straight - 2d reconstruction does not look perfect
PIX4Dreact is designed for speed and immediate situational awareness, particularly in emergency or disaster scenarios. As such, it is not optimized for generating high-precision orthomosaics or accurately reconstructing buildings. Some level of blurriness or distortion—especially around vertical structures—is expected.
For users requiring high-quality outputs or detailed 3D reconstruction, we recommend using PIX4Dmatic software tailored to those needs.
