Scale constraints - PIX4Dmatic
PIX4Dmatic employs Scale constraints as a means to introduce known measurements or references into the photogrammetric process, enabling the reconstruction of accurate and correctly scaled 3D models.
Scale constraints in the 3D viewer
Deleting a Scale constraint
Properties panel
How to scale a project
Important: There are two primary concepts for incorporating scale constraints.
- A Scale constraint is a line defined by two Tie points.
- A Scale constraint has a length.
Scale constraints are symbolized in the 3D viewer as a magenta line.
The Scale constraint can be deleted by right-clicking on the constraint while in the 3D viewer.
Properties panel
The Properties panel displays the length of the Scale constraint along with the accuracy of the line. When a new Scale constraint is created, the correct length must be entered in the Properties panel.
A Scale constraint is defined by two MTPs.
- Create an MTP. For more information: Tie Points (GCPs, MTPs, and CPs) - PIX4Dmatic.
- Select the Scale constraint
icon or use the keyboard shortcut T.
- Begin by left-clicking on a Tie point and finish the constraint by left-clicking on another Tie point.
Important: MTPs must be marked in the images for the Scale constraint to work.
- Enter the length of the constraint in the Properties panel.
- After drawing the Scale constraint, either Reoptimize or run Calibration (if not previously calibrated).
- Click Save...
