(iOS) Calibrate Parrot Bebop 2, Bluegrass, and Disco-Pro AG
The drone's compass may require calibration from time-to-time. We recommend that the compass be calibrated before each flight.
_ Note: If you are not flying with a Parrot drone, use the original drone manufacturer's app to calibrate the compass.
Plan your mission and then tap Next. Verify that your Parrot drone is connected and then tap Next. The Drone take off checklist will appear.
Calibrate your drone by tapping on the drone's calibration status.
Tap Calibrate to initiate the calibration procedure.
Rotate the drone around each axis according to the instructions.
Tap Done to complete the compass calibration.
Verify the drone's calibration status and tap Start to take off.
0 out of 0 found this helpful
